It is currently Fri Aug 15, 2025 1:44 am
 Post subject: Mount Extra Pot Strat
PostPosted: Fri Jan 12, 2024 10:51 am
Last Name: Roberts
City: Bentonville
State: AR
Zip/Postal Code: 72713
Hi,
I want to add a Fishman Powerchip to a Stratocaster. I don't have a drill press. My idea was to use a very thin drill to drill completely through the body to locate the top and bottom hole. Then from the bottom use a Forstner bit to create the cavity leaving enough wood for the shaft top and bottom nuts to sandwich. Then from the top drill the 3/8 inch hole into the cavity.
Am I on the right track? and would you attempt this without a drill press? I have searched the Internet quite a bit and "adding pot to solid body guitar" yields nothing useful.
Michael
PostPosted: Fri Jan 12, 2024 11:52 am
First name: David
City: Napa
Zip/Postal Code: 94558
I would recommend not doing this. Find a custom pot setup without drilling out the guitar that works.
These users thanked the author dofthesea for the post: Hesh (Fri Jan 12, 2024 12:35 pm)
PostPosted: Fri Jan 12, 2024 12:37 pm
I agree with David and I make my living drilling out guitars but where we do no harm. Do it in the pick guard region so it's reversible with a new guard when the power chip goes tits up long before the instrument does.
Welcome to the form Michael
PostPosted: Fri Jan 12, 2024 8:37 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
I suppose the OP wants to emulate Pete Townshend's setup. In which case he'd have to make a router template to guide the cavity on the back. But I agree, I'd rather choose to keep the body unharmed and route under the pickguard when I have no other choice. Well, that's what I usually do anyway.
Pierre
Guitares Torvisse
Pierre Castonguay
These users thanked the author Smylight for the post: Hesh (Sat Jan 13, 2024 7:33 am)
PostPosted: Sat Jan 13, 2024 9:19 am
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
I would change to a single master tone and put the pit for the power chip in the 3d hole
These users thanked the author CraigG for the post (total 2): Hesh (Sat Jan 13, 2024 11:54 am) • Smylight (Sat Jan 13, 2024 10:03 am)
cron
